migrate from vera to HC2
is there any instructions around on migrating  from vera to HC2 I have done a search but had no luck
Hi @buts,
Welcome to the world of Fibaro, we seem to be getting more Australians here every day!
Unfortunately though, there is no real method to migrate from Vera. The best method is to exclude devices from Vera and then include them on Fibaro. depending on your time frames and the amount of devices you have you can set up fibaro to control your Vera base devices using http commands as a stop gap while you work your way through migrating each unit.
this post may help:
Good luck with your new setup, you will find plenty of assistance within the forum comunity.
Edited by Robert Folbigg
I know FIbaro does not support this, which is pretty odd as, afaik, this is a mandatory requirement in obtaining Sigma's certification (SDS11847):
(paragraph 3.3.1)
Can someone from FIbaro comment please?
