Al3x 2
I seem to have a very bizzare issue that has wasted a good part of a day, i seem to have a web gui that has missing buttons, icons and sections. So for example i can add sections but i cannot add rooms, i can go to add users but i cannot save the new user. This is logged in as the super user.
So i go through the recovery and go back to 4.063 or something in the far past and they are still missing. Upgrading to 4.1, 4.130 or beta versions (number version might be off) and this does not solve the issue.
I was with fibaro technical support for over 5hrs today and have seen him run all sorts of commands as root, patch builds apply hotfixes etc but nothing seems to return the missing items.
I was wondering if anyone else has had this issue as it worked perfectly fine until i added a 50th room to one of my 6 sections.
attached is an example of a missing add room after the system got flattened and firmware flashed to older versions.
Chrome, Firefox, Safari and Edge all show the same results. Browser cache cleared etc. using incognito or privacy mode also does not work.
Fibaro technical support after so many hours said it was a manufacturing fault and that the issue was highly complex.
After all the messing around my recoveries etc are all useless now and i dont have a clue how i can export these as i do not fancy adding all my devices, rooms, sections, icons, config back again
