Christian Schnidrig 0
I’ve got an Aeotec ZW075 Switch which I would like to be switched when I press S1 on a Fibaro FGS223 Switch.
If I add the zw075 node to the 4th association group of the fgs223 everything is working as expected. When I press S2 on the fibaro, the zw075 is switched accordingly.
However when I add the zw075 node to association group 2 of the FGS223 then the zw075 switch does not change state when I press the corresponding switch S1.
I tried several zw075s and several fgs223s. All show the same behaviour. S2 is working fine, S1 is not.
Hoping to shed a bid more light on this, I did the following. (I'm using openhab2, the logs are from there)
- Lifeline -> removed controller
- group2 & group4 set to controller: “node_1_0”
This way I should see on the controller, what the fgs223 is sending to devices added to the association groups 2 & 4. Here are the results:
When pressing S1:
2017-08-17 20:43:34.785 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Application Command Request (ALIVE:DONE)
2017-08-17 20:43:34.785 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 18: Starting initialisation from DONE
2017-08-17 20:43:34.787 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Incoming command class MULTI_INSTANCE
2017-08-17 20:43:34.788 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Received MULTI_INSTANCE command V2
2017-08-17 20:43:34.789 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Requested Command Class = BASIC (0x20)
2017-08-17 20:43:34.790 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Endpoint = 1, calling handleApplicationCommandRequest.
2017-08-17 20:43:34.790 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Received Basic Request
2017-08-17 20:43:34.791 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic Set sent to the controller will be processed as Basic Report
2017-08-17 20:43:34.792 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic report, value = 0x00
2017-08-17 20:43:34.794 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-17 20:43:34.795 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got a value event from Z-Wave network, endpoint = 1, command class = BASIC, value = 0
2017-08-17 20:43:34.796 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Updating channel state zwave:device:0001:node18:switch_binary1 to OFF [OnOffType]
2017-08-17 20:43:34.815 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Application Command Request (ALIVE:DONE)
2017-08-17 20:43:34.816 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 18: Starting initialisation from DONE
2017-08-17 20:43:34.818 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Incoming command class MULTI_INSTANCE
2017-08-17 20:43:34.818 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Received MULTI_INSTANCE command V2
2017-08-17 20:43:34.819 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Requested Command Class = BASIC (0x20)
2017-08-17 20:43:34.820 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 18: Endpoint = 1, calling handleApplicationCommandRequest.
2017-08-17 20:43:34.821 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Received Basic Request
2017-08-17 20:43:34.822 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic Set sent to the controller will be processed as Basic Report
2017-08-17 20:43:34.823 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic report, value = 0x00
2017-08-17 20:43:34.825 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-17 20:43:34.826 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got a value event from Z-Wave network, endpoint = 1, command class = BASIC, value = 0
2017-08-17 20:43:34.827 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Updating channel state zwave:device:0001:node18:switch_binary1 to OFF [OnOffType]
When pressing S2:
2017-08-17 20:43:38.988 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Application Command Request (ALIVE:DONE)
2017-08-17 20:43:38.989 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 18: Starting initialisation from DONE
2017-08-17 20:43:38.991 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Incoming command class BASIC
2017-08-17 20:43:38.992 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Received Basic Request
2017-08-17 20:43:38.993 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic Set sent to the controller will be processed as Basic Report
2017-08-17 20:43:38.994 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic report, value = 0xFF
2017-08-17 20:43:38.997 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-17 20:43:38.998 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2017-08-17 20:43:39.000 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Updating channel state zwave:device:0001:node18:switch_binary to ON [OnOffType]
2017-08-17 20:43:39.024 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Application Command Request (ALIVE:DONE)
2017-08-17 20:43:39.025 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 18: Starting initialisation from DONE
2017-08-17 20:43:39.027 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 18: Incoming command class BASIC
2017-08-17 20:43:39.028 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Received Basic Request
2017-08-17 20:43:39.030 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic Set sent to the controller will be processed as Basic Report
2017-08-17 20:43:39.031 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 18: Basic report, value = 0xFF
2017-08-17 20:43:39.033 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-08-17 20:43:39.034 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2017-08-17 20:43:39.036 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 18: Updating channel state zwave:device:0001:node18:switch_binary to ON [OnOffType]
One can see, that S1 is generating messages for endpoint 1 instead of 0.
The question now would be why and can this be fixed?
