Dummy questions LUA
Hello all,
I use some VD made by expert members like @AutoFrank, @Sankotronic and others, an today i try some tests so i can understand how they made this LUA VD so great.
I'm beginner in LUA so please be gentle whit me, i just want to learn.
I start understand LUA but i have some question.
Now i play whit SONOS VD, and i have 3 buttons on same line, they have id 7. I try to call them in LUA but i can't call button 2 and 3....i have no idea how to use their ID...or how to find their ID.
For call button 1 (play) is use:
fibaro:call(1334, "pressButton", "7")
fibaro:debug("play!")
AND SONONS play!
But how to use rest of buttons, for example stop and mute, both on same line...
I really want to make my first LUA scene....so any support is welcome.
Edited by Mediacut
5 answers to this question
Hi @Mediacut,
You have to count the buttons, labels, etc. So if the button "Play" works with 7 the next will be 8 then 9, etc. Just try it and see the magic happen!
@Mediacut
Take the following  example ...
The label "status' counts as id = 1 so the buttons are
Gate open and close = 2
Gate open 4 mins =3
And so on
The first number before pressButton is the vd id itself and the number after if my (7 in your ecample) is the button id
    3 hours ago, boerremk said:
    Hi @Mediacut,
    Thanks, indeed works! I'm beginner.....:)
    20 minutes ago, AutoFrank said:
    @Mediacut
    Gate open 4 mins =3
    And so on
    Thanks,
    I need to learn more, I started whit LUA manual today.
    I really like your VD they are nice and useful.
    I need to learn how you show status value and temperature bellow buttons:)
    Other question,
    How to populate EX. label1 whit value from an ID status.
    Based on @AutoFrank example above, how to make label status (ex.gate) to take value from module that control that gate?
    @Mediacut
    If you take a look at the label id and the code in main loop you will see the connection between the code and populating the label
    I learned ( and still learn)  a huge amount from reading through other users code to try and understand what it is doing ...
