Sonos in scene
Hi guys,
I'm trying to create a scene in LUA for waking up where my lights go on and my Sonos starts to play a specific playlist or radiostation.
The lighting part is up and running, but I can't seem to get the Sonos to start.
Anyone got an idea what the LUA code is?
8 answers to this question
" to "
Temat został przeniesiony z "
" do "
2 hours ago, Snaad said:
Hi guys,
Hi @Snaad
Could you describe how you currently interact with your Sonos system. Is it through the Remote VD or the sonos-http-api ?
Do you have virtual devices for each player ?
    1 minute ago, AutoFrank said:
    Hi @Snaad
    Hi @AutoFrank,
    I installed the Sonos plugin:) I'm pretty much to this, so if I'm doing anything wrong, please do tell me so.
    24 minutes ago, Snaad said:
    Hi @AutoFrank,
    I've never used the Sonos plugin so I'm not sure
    Could you post a screenshot of what the controls for the plugin look like ?
    Does this work?
    You could also just upload the image to the post itself.
    I don't know much about plugins
    You could try the lua pressButton command and seeing if that works...
    You may be better moving to either the sonos-api ( running on rasspberry pi ) or the Remote vd as these are more flexible than the plugin.
    I'll a look at those, thanks:) If that doesn't work, I'll get back.
    @Snaad
    I wrote a tutorial on the sonos http-api
    You'll find a link in my signature with install, setup and examples
