Unable to Control Sonos
Hi all,
I am trying to setup a Sonos into my system so I can tell it to either play MP3 files on the net or TTS for the alarm system but i'm having a few problems getting the Sonos to connect.
If I install either the fibaro plugin or the plugin from Domoitque forum and play something on the Sonos the plugin's both show the Sonos playing radio but if I hit stop, play, pause or try to alter the volume they don't work. It appears to be one way communication! Anyone else had this problem?
Thanks,
James.
Guest spazpeker
1 hour ago, Nis said:
Hi all,
Thanks,
James.
do you have the v1.0.1 version ?
i had a similar problem and it was the X_Sonos_Object variable  just delete it and the virtual device will add it again
Hi, I'm having the same problem as Nis. it started after the latest Sonos update..
How did you solve this
 Where do you delete the X_Sonos_Object? from every button? Exactly what string should be removed?
Thanks!
Guest spazpeker
Go into variable panel and delete it there, when you use the Virtual device it creates a new in corrupted version
