Scenes with Sonos/Logitech harmony plugins/devices
I don't understand much of scenes. I am using plugins of Logitech harmony and Sonos. I can use this plugins, but I want to use them in scenes. Is this possible?  I don't see them when I try to make a scene, they are not showing up under devices. I can't select them. How to setup this to make it work. I want to start a fibaro wall plug and after that I want to start Sonos speaker with some music. Hope somebody can help me with this.
5 answers to this question
Hello!
@Robert66, where you cannot find those devices?
Usually, devices such as Sonos do not monitor anything so they shouldn't act as triggers.
Could you make and share a screenshot with us?
Finally, how do you do this scene? With graphic blocks? Lua code? Magic scenes?
    I can find  the  devices under devices. But not use them in scenes. I tried to make scenes  with graphics blocks and Magic scenes.
    Don't know how to get a print screen of  it. Using a Mac.
    @Robert66, you should find Sonos VD under graphic block scene:
    And to make a screenshot on Mac, you can use this key combination:
    Shift-Command (⌘)-3 - entire screen
    Shift-Command (⌘)-4 - part of the screen
    More info about screenshots on Mac on
    Edited by I.Srodka
    Ok, thanks..I used also the Sonos Plugin but this one is not a virtual device, so I guess can't use it in scenes?
    It's strange but the Sonos Plugin gives me a good setup, I can play music from the Sonos box then, but the Sonos Player (virtual device) did not so far. So I have to find out what the problem is so the Sonos Player is also working
    @Robert66
    It may be worth checking out the other two methods of using Sonos with hc2
    Sonos Remote
    Sonos-http-api
    You get a great leave of control and stability with these integrations
