[Feature Request] Space for PHP scripts on HC2
gucio1234
I would appreciate if users of HC2 box have access to some disk space to place PHP scripts there and have web server with PHP module active.
Presently I am using external web server to store and run PHP scripts called from HC2. That is needed for interaction with other devices/environment.
I guess that would be out of the box when Fibaro is running on Synology (that would be feature of Synology rather then Fibaro).
It would be beneficial to have this available also for HC2 users.
Hi @gucio1234,
As you suspect, it's a feature rather for more advanced users. I have forwarded your suggestion but the priority is on the projects impacting more users.
Edited by I.Srodka
Well, inner Web server is capable of runnig php and php is also installed in HC. So i think, there could be some user separated from others, that has access only to his files.
@I.Srodka, with @gucio1234s request i would add to it one web server for both HCs. Nothing againts Apache (in HC2), but i think NGINX (in HCL) could be more suitable for this (just mine opinion).
