No internet connection when connected via 4G
Since the last update I'm having issues that I cannot connect anymore when I'm connected via 4G (having HC2), it says "No internet connection".
Last week I installed also a new HCL at my parents house and they are experiencing the same issue.
When connected via Wifi, everything works fine.
9 answers to this question
@kimbo
Which fw revision are you on ?
I'm on 4.130 on a hc2 and can access over 4g without problem
    3 minutes ago, AutoFrank said:
    @kimbo
    For both HC2 and HCL the version is the same as yours. For my system connected to the HC2 it seems to be working again after a few attempts. Reconnect external and then connect internet and search gateway. Need to see if this will also work with my parents phone.
    Edited by kimbo
    @kimbo
    Could it have been a break or low signal situation with the network provider ?
    I have noticed that if I am in a low signal area I cannot remote connect as the fibaro app times out
    @AutoFrank
    Well the signal bar only displayed one in 4G, though I could connect. Will test it some more its behaviour.
    A nice feature is the finger print to disarm the alarm.
    Wish fibaro had already an alarm panel so I could arm/disarm next to the door.
    Edited by kimbo
    @kimbo
    Did your parents phone also work now?
    You can also try setting up Google DNS and see if it helps:
    @kimbo, are you using the App or the browser?  If you're using the browser please check if you have enabled internet access for the App (iOS)
    @Landshark, we are all using Android and mobile data is active all the time when not connected via Wifi.
    @kimbo, are you sure it is not disabled?
