Has anyone found a way to kick off sceneactivation from a Fibaro RGBW?
I have automated lighting that allows for wall switch override via sceneactivation on dimmers switches, but for the Fibaro RGBW I cannot get the override to work as there is no scene activation functionality on this device.
It creates a poor user experience where you have to explain to users to first click on a non-RGBW switch to manually override automated lighting before they can change the RGBW lights manually.
EDIT: The only way I can think of doing it, which I dread the thought off, is to hide a FIbaro Dimmer2 module behind the switch and connect it to the same switch gang as the RGBW. Then activate sceneactivation on the Dimmer2. Not what I want to do really.
Edited by amilanov
Hello @amilanov,
There is no such functionality as it is one of the first modules and it is not equipped with Z-Wave 5. To add scene activation, some other, currently present functionality has to be removed.
We have plans to release updated version with Z-Wave 5 but we do not know the exact time frame.
But I will pass your idea to our engineers.
Edited by I.Srodka
Guest spazpeker
What are you using the RGBW MODULE for ? Single leds, RGBW strips RGB strips?
" to "
Temat został przeniesiony z "
" do "
    Currently RGB strips and RGB LEDs.
    Going forward RGBW strips as well.
    Why does  it matter?
    I'm thinking out loud. If you want to use the existing switch(es)... a Fibaro UBS is an old device but it is small, runs on 12-24 V and has scene activation. And cheaper than "Dimmer 2". I do not think connecting a switch to both modules at the same time would work. No it would not work, they use different voltage on switch input. I'm not a big fan of associations, I'm not sure if it would work either. So you'd have to use device grouping (not sure that would work) or use scenes to glue the devices together. Just thought I'd mention it.
    Edited by petergebruers
    Guest spazpeker
    Why does  it matter?
    You might be able to use the white channel to trigger a scene, I have one in a test bed, I will try it and let you
    12 hours ago, I.Srodka said:
    Hello @amilanov,
    I wait with baited breath for the z-wave 5 module. Please release it in the next few months!
    I need around 30 modules to replace existing and install the new system.
    I was hoping I could power them separately that way when I have to rebuild the system I can reliably delete and add the devices by turn the other one circuit off, but my novice electricians mind didn't think through the ramifications or if it's possible to have two sets of wires coming from a single gang switch to two devices of different voltage.
    It would be interesting to see if it can be done. The issue, as I think you've all figured out is that you can't use "value" to trigger a scene otherwise as the devices is dimming up/down, turning on/off it would be kicking off unwanted scenes. Thanks for any help you can provide.
    Guest spazpeker
    Yes looks like you cant access the white channel when in RGB Mode.
    you could setup the device in input /  output mode, and use the first 3 for RGB and channel 4 for triggering a scene
    Thanks. I will have to have a think about this and play around to fully understand what you mean....
    I am still not sure how to trigger a scene from the white channel, even if in input/output mode. Remember that the scene should only be triggered when the user presses the wall switch***
    Also, if I set it up to Input/Output won't I lose the RGBW functionality e.g. being able to change colours through the various interfaces?
    I'm also not sure what impact this would have on my code, turning on/off the channels when it is in input/output. It seems very promising though. Food for thought. Thanks!
    ***Fibaro, please, please look into adding in a long outstanding feature that I and I am sure many other users have requested. The ability to distinguish what triggered a changed in the value of a device e.g. was it a scene and if so which scene, was it a physical interaction, was it from a device (tablet, mobile, web interface). We need to be able to see what changed the value and also be able to code with different interfaces (scene, physical, device etc) in LUA so that we can determine, for example, if a light is being dimmed down because a scene is dimming it or because someone has dimming in manually via a tablet or via a wall switch and do something different based on the interface (means by which the device was interacted with) interacting with the device.
    On 8/30/2017 at 7:37 AM, I.Srodka said:
    Hello @amilanov,
    "To add scene activation, some other, currently present functionality has to be removed. "
    I would happily give up one of the functions to have scene activation added to my RGBs via a firmware update. You could make the update optional for those that want sceneactivation enabled and are willing to give up something in return e.g. I personally have never changed parm 44, 45, 71 or 73 from their defaults.
    Edited by amilanov
    This suggestion was submitted in April
    And it is being discussed and considered to be implemented. We have to wait for decision.
    Thanks for that. Good to know.
    There was also an associated issue raised by me on bugzilla almost 2.5 years ago (
    ) supported by almost 20 people before bugzilla seemed to die off:
    Ability to see which device triggered an event in the event panel.
    (A) In addition to what the event panel reports currently, it should also show:
    A1) Source of trigger e.g. android app, ios app, web interface, wall switch, scene, virtual device
    A2) ID of device triggering the event
    (B) Users should be able to navigate the event panel through the following means:
    B1) By date/time range
    - as per current functionality
    B2) By device triggered
    - should be able to select from every device in system and limit search to only selected device(s)
    B3) By triggering device and/or triggering source
    - as per B2 above but by the sources/devices included as part of the request in A1 and A2 above
    My request in the post above extends beyond the event panel to full integration into the HC2 with full access within scenes.
    Dannyboy's request was also a good one:
    I am glad Fibaro is looking into it.
    Regards
    Aleks
    Edited by amilanov
    • 1 year later...
    I would fully support a little bit more effort by the Fibaro R&D on this topic.
    Please add a kind of Scene control to the Fibaro RGBW device. :)
