Radu Crisan 0
Hello.
I made the mistake of buying a Qubino Smart Meter and struggled with it and it's impossible cohabitation with Fibaro HomeCenter2.
Of course, as an innocent newbie, I wrote many times to both Qubino and Fibaro Tech Support and got general-available responses as: "should work", "no need for templates", etc.
Well, the thing with Qubino Smart Meter is a tricky one. For some users (and I saw on this forum a user from Romania with the correct display of values) seems to be working fine. Not for me. It always displayed the wrong decimal places for Intensity and Total Power, hence the missing cos-phi power factor. I deleted, reincluded and reconfigured the device over and over again. I mean, having a 26,1 Amps from a single light-bulb would be an extreme realization, don't you think? (attached picture).
The device parameters were manually added but I couldn't intervene too much in the HomeCenter interface to modify the decimal as in the manual some parameters were 1,2 or 3-byte decimal and in the interface, I couldn't select anything but 2d or 4d .
I tried to learn a thing or two about api and commands via REST-console. I am not a programmer but I am eager to learn and make the stuff work.
For this particular device, I tried, after reconfiguration, to update the parameters via REST-console. Bu no matter how many times I am sending this:
the result is this:
Sincerely, I am over my head. I believe that some will think about this as a newbie problem, maybe I am too into it to figure out the obvious, but I really really need help understanding and addressing this problem, as well as how to solve it, how to add correct parameters and to make a goddamn 150 EUR device (QubinoSmart Meter) display some values.
Thank you
12 answers to this question
