Strange CPU load
sonnyboy
Could someone explain this to me, when i have my hc:2 open in a tab in chrome i got cpu load to the left on the picture,
When i go to another tab with another site and read that and then go back you se that the cpu load is getting very high??
Is this normal?
7 answers to this question
Is this normal?
I have reported it a while ago. But I think it's the NSA spying on us when we are not watching ;)
Is this normal?
i just tested it, no problems here, i must say i use a pihole so there is no change anything will be reported to google analitics or something like that
Hi @sonnyboy,
Does this behavior influence something directly?
Those CPU peaks differs from user to user and it depends on their particular system configurations and HC setup.
Edited by I.Srodka
  • Hello @I.Srodka
    The system is rock solid and works as it sholud, acts fast and have no problem.
    I have seen this in many Fw:s so its not something new.
    When the tab is active and you look at the cpu load its low and nice, but when you go to a diffrent tab the peaks just go crazy, witch one should i trust?
  • Cpu is still going crazy, at this picture you can see when i am in my fibaro active tab.
    Maby its time to set up a pihole as @akatar has done, i got an old pi somewere ;)
  • I get a Pi-hole up and running :)
    But why does my HC:2 connect to Google so often?
    5 hours 12619 times just to google??
    17061 request total from my HC2 in 5 hours
  • My Cpu problem goes on.
    Cpu goes bananas on 4.153 Beta,
    'Is there any way to export the Cpu load to some database like Mysql or influxDB.
    Everything works just fine.
    The load that goes from 100 is when another tab is active
    Edited by sonnyboy
    Spelling
