eureka 9
Hi all,
I created a day/night scene which has worked for a while but for some reason it stopped working and I can't find what the issue is. I debugged the whole thing and then it seems to work. Sometime when I resave it, it sets the variable to day or night once. After that it doesn't continue. Sometimes it just doesn't do anything.
Does anyone understand what I'm doing wrong?
Edited by T.KonopkaPlease, check if you post in the correct catergory: "If you need help in finishing your solution, then post in Developer forum".
