Single Switch 2 (FGS213) - Wiring toggle switch
Hi guys
I have a problem with the toggle switch wiring of the single switch. I have a room with 2 switches (toggle) and a power socket. I installed the Fibaro single switch 2 into the switch socket where the lamp cable is located (connected to Q port). According to the manual, the S1 port should connect with the other switch in the circuit so that both switch can be used to switch the light on/off. However, the second switch also serves the power socket so that I cannot connect it to S1 port because it needs permanent power. Both switches are also connected with black and grey cable (COM ports?). Any idea how to wire in this setup?
Daniel
