Detecting home presence
Hi guys,
I am looking for the most robust way to detect home presence. It has to work 100% of the time, since all the home systems are dependent on it, including the alarm system and video surveillance.
With my current setup, when approaching the house I have to push a VD button that changes a presence global variable. Is there a better alternative?
The options are:
- checking house wifi for a phone presense
- tracking GPS of the phone
- installing a z-wave device in the car (and changing a global variable if this device activates on the network)
...anything else? would a combination work better?
Thank you,
Ros
Edited by Ros
there is a VD floating around the forums that uses your phone's MAC address once you connect to the home wifi network, but i have heard from a few of the users here that have mentioned its not 100% perfect..
I'm using this one and it works quit good (based on the MAC address of your mobile phone)
A good alternative is  the scene created by @jompa68
Edited by Landshark
