falbering 0
Im trying to update a couple of numaric values not using the slider as the slider it so sensitive and does not get to my desired value.
When i key in a number by hand this number and hit the save button the number seems not to be saved. in the advanced tab it does say " last set value 130" as i wanted, but the number in the blue box is still the old value.
In my case its parameter 9:
Parameter 9
This parameter determines the limit of the light intensity level for parameter 8
defaulted to 200 i want it to be 130. Same behaviour is happening for other numaric values where the slider is not usefull.
How do i change this?
Thanks,
Floris
