Accsoiation issue with FGWP102
Guest Erik-DK
Hi
If I do an association from a contact to a FGWP102 nothing happens, it works from the same device to Relay2, dimmer and other devices (except the FGWP102)
I have tried several and also taken a brand new and associated, same issue
I see in the event panel that the contact is activated.
A scene is not working towards FGWP102
so ???
Regards Erik Loeth
Associations are not my cup of tea. But I might have idea. Did you try column S instead of M?
@Erik-DK,
You can find more about Associations in our
 and you can check device-specific associations in their manuals, here is the info about Wall Plug:
Guest Erik-DK
    But S is not helping, and the info as I read it is for the plug to control something.
    The assioation I want is from a wall switch to control the on/off of the FGWP102, it worked before but stoped working after update to 4.140
    If I associate the same wall switch to a relay2 it works, if I do it against a Greenwave Systems NP210-KF-S port it works. It is only the FGWP that fails.
    Regards Erk Loeth
    Out of curiosity: what brand and model is your wall switch?
    @Erik-DK
    During the association setup, you define the group number as well.
    In this case make sure that your device support the group number and usually you need to configure the command frame and data for the group.
    According to your picture, you're talking about Fibaro wall plug. As far as I know this device supports only two groups. (in your case you're trying to configure group 6, which is not supported). The third group usually reserved for controller.
    Please refer  to Parameter 52 setup (see attached picture).  You probably need to set to default value.
    Please try to configure group 2 for association.
    As far as I know this device doesn't support multi channel. (Has only one end point).
    All suggestions above related to Fibaro wall plug, but all devices have same concept.
    Edited by cag014
    " to "
    Temat został przeniesiony z "
    " do "
