burned fibromodule by short circuit due to unknown cause
Hello everyone, I'm quite a complicated problem, namely ... somewhere mid July, the Fibaro shutter 2 switch has been burnt due to a overvoltage, can happen, I replaced these with a new one month later, I had the same problem.
Burned again and replaced by another, however, a couple of hours later as I watched the TV in the evening, I suddenly heard a loud crash with a great bang and the module again.
This happened for no apparent reason ... suddenly out of nowhere.
I thought the roller coaster was the same .. I'd also fibaro relay switch in the crawl cellar that was a week ago.
This morning I put on the basement light, a great bang, short circuit and a burned fibaromodule.
Throughout the week I did not bother, that worked all the way it was heard and suddenly and randomly and for no apparent reason.
For info: I have placed 48 hue lamps and feel that since the problems have begun.
Is there a connection between hue lamps and a short circuit on the fibaromodules ?
Does anyone have any idea what could be the cause / solution here because ?
I'm in the end for the moment.
Hi @defender,
We're really sorry that your Fibaro Shutter 2 burnt.
However, it looks like an issue with your electric network.
Please keep in mind maximum loads for Roller Shutter 2:
And that your electrical system should be protected:
    @defender,
    Thank you for sharing this with us!
    I hope it will make at least some members more cautious in the future.
