How to wake up door sensor through scene ?
How to manually wake up door sensor through scene without using TMP button ?
Please help. Thanks in advance.
Hi @Rajesh,
There is not option to explicitly wake up Door/Windows Sensor through scene.
Exactly, depending on what you are trying to achieve you will have to set parameters for the device for example.
If you could share what you try to do, we can think with you :)
is't a non listening device,,
so it won't listenen (only at preset times)
