Try to understand how scene are triggered
Hello
I've wrote a little scene in LUA, and I still do not figure out how scene are triggered
For the result in the debug windows with this code should loop.
and should look like
But the result of the execution is that one
only 1 occurence of the execution.
Can someone explains what's triggering the execution of the scene
I found the explaination.
How this is working
Scene got activated once. If you want to have a reoccurence of the activation you need to create a function and write inside what the part of the code you want to reexecute.
and at the end of the function use the fibaro function
    setTimeout(nameofmyfunction, 60*1000)   -> 60 is 60 secondes.
The code should looks like
Edited by pixys
I found the reason
7 answers to this question
yes that is correct :) this will make the scene loop continuously.   Try not to have too many of these in the system thou.  My advice would be to have one scene running in a loop - the main scene , and all the others triggered by variables, devices and so on.
    I've got 7 in total 1 per heating control.
    I understand the main loop
    Do you have any sample of a scene trigger by device or variable ?
    Pixys
    Here an example of scene triggered by devices
    Please note:
    I'm using json table for device IDs, but it's actually the ID numbers of the devices.
    I have changed first two cases to actually ID numbers for your convenience.
    Here an example for global variables
    I don't use
    %% autostart
    It means the HC2 will not execute the scene on startup (e.g. after reboot),but it will be executed only if triggered.
    Although the scene mode  must be set to Automatic
    Edited by cag014
    Thanks , I will have to read it twice to understand all the concept ;)
    Here is a very simple example for device property trigger
    Hope it more understandable
    Edited by cag014
    Hello
    Yes, It looks clear now.
    " to "
    Temat został przeniesiony z "
    " do "
