FGRGBWM-441 and light switch
i would like to install such a module in my living room, to control a led strip
I could easily set it up, but i would also like to use a switch on the wall to turn leds on/off
The perfect scenario would :
when i use the laptop to configure my strip, i can turn it on/off change color, etc. As if there were no switch on my wall
If i push once on my wall switch, it turns on the strip with 100% white light, or with the last used configuration (i dont care which of those, but nothing else)
if i push a second time on this witch, it turns off
Is there a way to do that ? If yes, what should i configure, cause i cant find how to connect that switch and what to configure
PS : im using Jeedom
thanks for any help
    up
