Android Turn on Screen using camera detection
Hello guys, do you have any suggestions or ideas how to configure motion detector to trigger the display to turn on when  a motion is detected in the room? Something similar that Nest Thermostat has? When  you walk in the room to turn on the screen? I need that for my tablet which is mounted on the wall. Thank you in advance for the tips
Edited by T.Konopka
It is related to the update.
4 answers to this question
Guest Lode
It will cost you a few dollars but it works fine.....
Let me know if it works......:)
    Hy Lode,
    Yes , it`s working , But not on my Xperia Z3 tablet ....on G8 is working fine...The both OS are not rooted. Any suggestions? :) Thank you a lot
    i use Imperihome and work very well, but if you need a Fibaro app, i don't know any program
    " to "
    Temat został przeniesiony z "
    " do "
