Heating panel fist morning temperature
The first morning temperature does not seems to work. I am not able to change it, the first temperature is assigned to the second day period. I think the last temperature should be assigned to the last day period plus the first day period, but as you can see, it changes only the last peeriod. I dont seems to have option to change the temperature between 5AM and lets say 7AM.
As you can see on the picture, there is not 18 degrees selected and the first temp in the morning still shows 18 degrees.
Edit: Ok, it shows correct setting after i click copy to all weeks. But I think it used to change with the last temp directly.
Edited by HomeSystem.sk
For the whole day you have 4 moments to change temperature, so that's why you can edit 4 temperature values.
The last change is at 2am, for 19deg, and you shall have19deg till next change, next day.
So you may have 18deg at the end of Saturday, and it is continued at Sunday...
" to "
Temat został przeniesiony z "
" do "
