LUA get parameter values
Hi. I'm an experienced programmer, but a novice in LUA.
1.
I have some qubino smart meters, and would like (of course) to read all the parameters they can provide.
It seems to me that every single parameter in them get an ID in HC2. When I want one of the values, i use fibaro:getValue(63,'value');
But: For some of the parameters there are no ID's! So how can I get their values? Examples of missing parameters are 143: Reactive power total and 144: Power factor total
How can I get to those?
2.
Is there a way to get parameters based on the device parameter numbers? I'd like to use some function v=fibaro:getParameter(main id,parameter number);
Is this possible?
3.
Where can I find a list of legal parameter values to the getValue call?
Helgemor
What you want can be done directly from the edit screen of a scene.  So make a LUA scene. While in the editing screen of the scene mouse  over the device list on the left side. By default devices in this view are grouped by  room, but when you mouse over a room name it will show the device list in that room and then the parameters of the device. Clicking on one of them will introduce in your LUA scene the required function to read that parameter.
Edited by Momos
    @MomosThanks! You have to be steady on the mouse, but at least, the information is available.
    Do anyone now how this is done in Home Center 3? I want to use a value of a device parameter to trigger a scene.
