Fibaro motion sensor and light sensor
i would like to set my motion sensor in my kitchen, the variables I would like to set are the movement setting (done) and the light sensor, basically when there is a certain  % of light I would like to disable the sensor...
is this possible?
5 answers to this question
type here:  motion lights
and here is search result:
and finally
; (Full support for HUE VD & plugin, dimmer, RGBW, switch & plug) New version coming soon
profit! :)
PS: Also you can find 100500 sorts of motion lights scenes in search...
    Thanks 10der your advice is very usefull, I apologize but the structure of the forum is not definitely user friendly to me!!! When I posted I was not 100% sure that I was in the correct area!
    anyhow as I said thanks for your help I’ll read the topics ;)
    btw
    19 minutes ago, 10der said:
    btw
    Thanks 10der, but the fact is that I have not a Home Center 2 System, I'm using the FGBHMS-001 HomeKit con Multi-Sensor through the homekit app, I had succesully with the automation of the philips hue lamp when the sensor detect the movement, what I'm trying to do is setting is the trigger accordingly with the light sensor...
    But looking in the forum it seems not possible....
    show me your script or LUA code
    Edited by 10der
