Aeon Labs Micro energy switch cant be set to momentary switch
I use some of these switches around my house and for most of them i have bought a touch panel which uses the momentary switch feature.
This has been working fine until yesterday when i bought some more touch panels and found out that i cant no longer set manual parameters on these switches.
Is there another way to do this?
5 answers to this question
" to "
Temat został przeniesiony z "
" do "
Can you tell me which models or versions work properly? And which you can't use?
    Hi T.Konopka,
    All of my devices are working but when i have upgraded FW (Not sure which FW that this option was removed) there is no way to set manual parameters for my Aeon Labs Micro switches.
    Before i could add parameters to set these as momentary switches but now that option is not showing anymore.
    BR
    I have same issue. Cant set parameter for this switch. It worked for 2 years without problem, but I excluded and included it again and this issue occurred.
    Hi T.Konopka,
    Will you add possibility to add parameters again for these devices?
    Right now i cant use these "manually" since they are not configured as momentary switches.
    BR
