LasPro 0
I wonder wheter I can use the roller shutter 2 module on my elctronic shutter control for my Somfy Glydea35 DCT electronic curtain.
The connectors 11,13,16 (see attached images) should be fine to connect the shutter module. But as far as the shutter module is powered by 230V I ask myself if the common ground (N) of roller switch and power supply of the module will burn the curtain moteor control.
What do you think ?
