FGS-223 switch 2 with 25A contactor
I need to manually declare power consumption with a switch 2 FGS-223.
I am using one of the relays to drive a contactor. This is working without a problem.
The energy of the contactor is 1W and I need to show the 750Watts of a pump.
Is there a possibility of using Lua if it is not possible to do this with the template?
Edited by Juky
I ask same things, i use contactors for swiming pool pump.
You can write here, maybe we become more, this will be add to a new update.
