Zipato Keypad - Syncronization does not work
I´m trying to synchronize my zipato keypad in order to start using it, but nothing happens.
Icon is changed to indicate loading,
But then after a minute or two it just reverts back to the default state. No messages or errors whatsoever.
Any ideas?
4 answers to this question
I am using it succesfully in my HC2's.
Make a new scene (lua) and use this:
Quote
%% properties
%% events
%% globals
local rfid = xxx -- Enter your RFID Reader ID here
fibaro:call(rfid, "setUserCodeDec", "x", "0,0,0,0,0,0,0,0,0,0"); -- replace x by a sequential ID, starting with 1 for the first ID you'd like to add. Replace 0,0,0,0,0 with the ID of the tag.
fibaro:call(rfid, "setUserName", "x", "NAME"); -- replace x with the ID as in the previous line and NAME with a name of the tag owner.
In order to get the code of the tag, include the tag reader as you with with any device.
Then, on the reader, click home and present the tag. In the top part of the HC2 web interface it will report it saw an unknown tag with ID 0,0,0,0,0,0.
This long number, including all comma's, copy/paste all into the scene above. Also, the ID it shows for the reader  in the logging at top, place that in the scene above.
When altered the scene, save it and launch. You will not see anything. Now again present the tag to the reader. Nothing again seems to have changed.
However, your zwave device is now receiving the new values. Wait 3 seconds and try again. You now will see that user ID x (depending on what you configged X for in the scene above) has been presented.
When you have this to work you can  create new scenes to initiate actions, based on something like this:
Quote
  local RFID = 123
  local ReaderValue = tonumber(fibaro:getValue(RFID, 'value'));
-- for mode away on tag reader:
  if (ReaderValue == 1) then
Edited by MaTi
Sadly LUA coding is not a solution for HCL owners... Hope Fibaro will soon solve the synchronization problem
Any ideas?
I had the same issue and solved it by letting the keypad stay for 20 minutes very close to HCL, maybe 15 cm apart.
