Hi Guys,
I would like some clarification on scenes if you could help me that would be great.
Basically I have created scenes to turn on lights when the motion sensor is breached then off after a set time. I keep getting notifications of "Number of instances of scene has been reduced due to exceeding limit.
is this because the motion sensor keeps seeing motion and trying to run the scene again?
If so how do i fix this?
Regards
Sean
10 answers to this question
Try to change the condition:
"if the motion sensor is breached" change to
"if the motion sensor is breached and the light is turned off"
    ah ok great. thank you ill give it a go
    ok so that fixed it for a couple of the scenes but still doing for one. i have attached an screen shot of it.
    Am i doing some wrong?
    It seems to be ok. If doesn't work then check trigger section. The motion should be checked in trigger section.
    It is checked but thats not the problem. it saying there are too many instances of the scene running
    Any ideas I'm still getting this problem
    Hi @smolson00,
    Could you post a bigger screenshot with triggering conditions above as well?
    because everytime there is motion it triggers the scene, so a lot of instances.
    Select the checkbox from the downlights and not the motion sensor. or convert to LUA and add
    if (tonumber(fibaro:countScenes()) > 1) then -- > 1
      --log("Script already running.");
      fibaro:abort();
    Ive attached a screenshot.
    1 hour ago, I.Srodka said:
    Hi @smolson00,
      fibaro:abort();
    ok great, thank you ill give that a go.
      fibaro:abort();
    %% properties
    15 value
    119 value
    %% weather
    %% events
    %% globals
    if (
     ( tonumber(fibaro:getValue(15, "value")) == 0 )
    and
     ( tonumber(fibaro:getValue(119, "value")) > 0 )
    or
    then
        fibaro:call(15, "turnOn");
        setTimeout(function()
            fibaro:call(15, "turnOff");
        end, 300000)
    if (tonumber(fibaro:countScenes(21, "value")) > 1) then -- > 1
      fibaro:abort(21, "value");
    is this correct?
