[SOLVED]Logitech Harmony Ultimate Elite
Hi, is there a complete VD available for Logitech Harmony. For now I have installed the Harmony plug-in but I only see the VD for the activities
i made. I want to use direct commands for my devices i.e. turn off command for my TV so i can use it in LUA.
The following properties and actions i see in the VD Activity watching TV:
Typ: com.fibaro.logitechHarmonyActivity
Properties:
- activityId
- dead
- deviceControlType
- deviceIcon
- log
- logTemp
- manufacturer
- model
- remoteGatewayId
- saveLogs
- ui.activityCurrentStateInfoLabel.caption
- ui.activityCurrentStateValueLabel.caption
- ui.startStopActivitySwitch.captionOff
- ui.startStopActivitySwitch.captionOn
- ui.startStopActivitySwitch.value
- userDescription
Actions:
- changeActivityState()
Edited by Labtec
text format
5 answers to this question
There is no way to send direct command to Harmony. The only way to do it is to define activities for every command that you need.
For example create bed-time activity which includes all necessary commands (this turns on/off TV, AV receiver, satellite box etc.) and then you can activate the activity by Harmony plug-in.
Edited by cag014
" to "
Temat został przeniesiony z "
" do "
@Labtec,
Did you find an answer to this?
I want to configure a bed-time scene which can trigger the Logitech OFF command (this turns off TV, AV receiver, satellite box etc.)
The logitech plugin has a single ON/OFF button but I think just off should be possible.
Maybe need to send the HTTP command directly?
Thanks, Elton.
    Thanks!
    Sorry for the delay in replying.
    Yes, this works perfectly! Thanks.
