Z-wave module parameter set-up via scene
I'm looking for a way to send a value to a module parameter directly from scenes in HC2. Can you help with for instance LUA syntax for such a command, if any?
Eg:  I'm looking to change the sound of a AEONLABS siren pending on scene in which I use it. Thanks
This topic might be a starting point:
