SebastianD 5
I recently found out that the IOS app (and possibly andoid too, I didnt test it) contain a severe bug when comes to providing connection to IP cameras. In my case I use cameras from Vivotek which offer quite professional firmware with a lot of scripting possibilities. So whats wrong?
Every time the app opens and you select a video feed, it will open up a connection to the camera. So far so good. However when you close the app, or the device goes into sleep, the app WONT kill the established http connection. Next time you open the app, it will -again- create a new stream connection. Since every IP camera has a restricted numbers of open connections, this behavior will lead to blocking the camera with abandoned connections, which makes it necessary to reboot.
I spoke with vivotek technicans in taiwan, and they confirmed that this can only be resolved within the app, and not in the camera.
So I ask Fibaro stuff to have a look into this, because this needs to be fixed. At the moment I help myself with a cronjob which reboots 8 cameras twice a day, but that is obviously not the way to handle that problem on a long run.
Sebastian
