Ip camera preset http link
Hi!
Im totally noob on Lua and im trying to make front door ip-camera to change its preset and take a picture when someone presses our front door bell.
How the code should be...?
The link works.
Its like this: http://192.168.1.155/decoder_control.cgi?user="user"&pwd="password"&command=43
Thank you very much!
-Tomi
7 answers to this question
" to "
Temat został przeniesiony z "
" do "
did you look there?
and finally
where 522 is front doorbell button.
2 - it's me
    Hi and thanks for the answer but i have to be honest, im not sure did you answered to my question :D
    Camera works fine and even sending the picture works when i press the door bell but i dont know how to make the camera auto move to the preset position where my front door is (number 6 is the preset number and "command=43" moves the camera to the correct position when i run the "http command" by pasting it to the web browser.
    Thank you!
    Ahhh!!! Sorry, I am stupid :)
    UPD: if cam says HTTP 200 OK immediately upon (!) new relocation - please simple remove "sleep" function from code  ...
    Edited by 10der
    Hi!
    For some reason it doesnt work... :/
    Here is the full code with changed password.
    Hope you or someone else can help me.
    The camera goes immediately to front door if i execute the link on internet browser :/
    %% autostart
    %% properties
    160 armed
    %% weather
    %% events
    %% globals
    if(startSource["type"] == "other") then
        setTimeout(function()
            fibaro:call(129, "sendPhotoToUser", "2");
        end, 2000)
    else
    if (( tonumber(fibaro:getValue(160, "armed")) > 0 )) then
    local delayedCheck0 = false;
    local tempDeviceState0, deviceLastModification0 = fibaro:get(160, "value");
    if (( tonumber(fibaro:getValue(160, "armed")) > 0 ) and (os.time() - deviceLastModification0) >= 2) then
        delayedCheck0 = true;
    if (
     ( delayedCheck0 == true )
    or
    then
        local httpClient = net.HTTPClient();
        httpClient:request('http://192.168.1.155/decoder_control.cgi?user=admin&pwd=thesecretword&command=43', {
          success = function(resp)
              fibaro:sleep(1000 * 5); -- waiting for... for example 5 sec
              fibaro:call(119, "sendPhotoToUser", "2"); -- say cheese
          end,
          error = function(err)
            print('error = ' .. err)
          end,
          options = {
            method = 'GET'
        end, 2000)
    Thank you again!
    Sorry, I have some old models of FOSCAM without moving functionality, so my question is what doesn’t work?
    can you create empty scrip with my code?
    also add in succ fibaro:debug[“Hello”)
    and run this script manually without params ahead
    thnx!
    Ohh,!! Another question for u
    can you run your url in incognito browser mode?
    r u sure what do not use basic auth for example and your browser save your credentials?
    what HTTP response code after GET?
    can u add some debug information to fibaro log?
    sorry I am on phone...
    Edited by 10der
    Hi.
    Thank you for helping me resolving my problem but i havent been able to test the code right now because i had to rethink my configuration all over.
    I couldnt connect my existing door bell buttons wiring straight to fibaros door sensor.
    I need to use transistor to make it work right.
    The door sensor went mad when i tried to connect it straight to door bell wires, it seems that there is power on those wires(didnt check that before i tried it).
