Fibaro Relay with an association to Fibaro door window sensor
Can I switch the
"Fibaro Relay Submersible Insert 1 Switch 2,5 kW, FIBEFGS-212 (Fibaro RELAY SWITCH FGS-212-EN-A-v1.1)"
on and off whith an
"Fibaro door window sensor FGK 101 Gen 5"
directly with an association?
Without home center!
I have a association  from the "Fibaro door window sensor FGK 101 Gen 5" to the
"Fibaro Relay" (2. "Control" pis assigned to the magnetic sensor and IN input. Opening or closeing will result in sending BASIC SET control command to associated devices)
The Fibaro Relay don't switch on/off wenn a access alarm is send.
I'm also have a Fibaro Wall  Plug. The Wall Plug switch on and off when the door sensor switch on/off.
