Double Switch - toggle button doesn't work after inclusion
Hello, I've installed a double relais behind a toggle button to operate a lamp. The button worked, until I added the relais to my Fibaro HC2. Since than, the lamp can only be controlled via Fibaro, not anymore through the toggle button. I can't figure out what is causing this. Wires are fine.
Have you checked toggle switch parameter 14  to 1 ?
default is 1,    0 for momentary switch
or try  soft reconfigure
oh and if its a switch 2 and not a relay  its parameter 20
Hi @bjbrink,
Parameter 14 is by default set to 1, as it was suggested above, you can try to set it to 0:
" to "
Temat został przeniesiony z "
" do "
    Thanks for the reply. In fact, it is a double switch, so parameter 20 is set as Toggle. And I also see a property Local protection that I think might be causing this?!
    Edited by bjbrink
