Lucano99 0
I would like to ask you for a help, or your opinion...
I have temperature sensors in every room (About 10 rooms). Each room has a Danfoss radiator head and.... I have a 1 pump, connected to the Fibaro relay. This pump is on the storage tank, so, if I want to heat the house (or room), this pump must be runned.
No, I have a switch in the storage room, so I can switch it manually ON and I have 1 room connected to this pump (in linked devices). But now, as I am trying to connect another temperature sensors, etc.. I need to configure the system that room with lowest temperature will power ON the pump.
Each room has different temperature settings - depence on time - bathroom, living roon, bedroom... (seems me to be logic) and if the temperature is lower then the setup, I need pump to be run (if already isnt), but I cannot setup more linked devices to the pump (If I setup 2 or more linked devices to the pump, it switch on and off the pump every minute
Do you have please any idea?
I would be very thankful.
Thank you
Lukas
4 answers to this question
