cannot update global var via API PUT request
10der
curl -v -H "Content-Type: application/json" --user "[email protected]:microsoft" -X PUT http://192.168.1.36/api/globalVariables/MySuperDuperVar -d "{value: '444'}"
so, before update value is 222
I am trying with 444
but after still 222
what I do wrong.
btw: via http://192.168.1.36/docs/#!/globalVariables/modGVariable all OK
network inspector looks like my request. crazy!
from powershell
Invoke-RestMethod -Method PUT -Uri $url -Credential $cred -ContentType "application/json" -Body '{"value":"777"}'
Invoke-RestMethod : The remote server returned an error: (405) Method Not Allowed.
At D:\Program Files\pc_locked.ps1:34 char:1
+ Invoke-RestMethod -Method PUT -Uri $url -Credential $cred -ContentTyp ...
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
Edited by 10der
4 answers to this question
  • Please login or register to see this image.
    root issue:
    "value" should be quoted.
    Hey Fibaro guys, are you using a handmade json parser?
    lol
    Edited by 10der
    Hi.
    Wie soll ich es eingeben?
    Bitte um einen Tipp. Danke dir.
    http://192.168.1.36/docs/#!/ globalVariables /modG Vari/{"Wert ": " 444 "}
    Or?
    http://192.168.178.111:80/api/globalVariables/HomeAssistant69?value=111
    Edited by parip69
    Hi. Can no one write me anything with a Example?
    I would like to set an existing variable from outside via HTML.
    Ask for a solution.
