Feature proposal: Snapshot scene function
I miss a feature currently in the fibaro home center 2: It is very hard to create a scene which reproduces the current state of selected actors.
For example I want to create a scene which reproduces exactly all actor states which I have currently set in my living room (roller positions,
dimmer settings, light switches, rgb values etc.). To do this now I have to collect all data manually in a very clumsy way, then to write a lua
script which sets all the actor values. I want to do this with only a simple button press, then a dialog shall appear which shows all actors
available and I want to select the ones which I want to include in my snapshot. After having done this a lua script shall automatically be
generated, which I can use or extend simply manually again.
This would be a great enhancement in simplification of using the HC2!
Currently I can't even read directly the roller positions or dimmer light values from the GUI. Bad!
