Aeon Labs Multisensor 6 and light timing
Guest Murakami78
Hi everyone
I have a multisensor 6 that I want to use as motion sensor for trigger on a light and then turn it off after 20secods
My problem is that when the sensor is breached than I have to wait about 90 second for my sensor to become safe again.... I can't find the parameter to set this time.
Thanks. Luca.
Edited by Murakami78
5 answers to this question
Luca,
There is a parameter for that for this device. It is parameter 3. In my case I have set it to 30 meaning that after 30 seconds of no motion the device will send the safe status to the controller. Please see below:
Roland
Guest Murakami78
    I have already set it to 30sec but I have to wait a minute and half to see the sensor become safe.
    I dont know why
    After setting the parameter in the HC2 did you wakeup the device to get the new value ? If not it will only pick up when it wakes up at the wakeup interval.
    Guest Murakami78
    Is this the 111 parameter?
    "The interval time of sending reports in Report group 1"
    I have set it to 60sec
    I was referring to the wake-up time as define in the advanced tab of the device, so for me an hour:
    If you want to force the sensor to pick up changes, just press the button at the back of the sensor, it will then get and process the new settings...
