Dimmer 2 not turning completely off
George Basco
I have 4 x 4w LED bulbs in a fixture that will not turn off completely with a Dimmer 2.   If I change one of the bulbs with a different type of LED, the problem goes away, but when all 4 are the same 4w bulb, they do not completely turn off.
The Dimmer 2 is wired with a neutral, so seems odds that it cannot turn off the load completely.
I have not tried a bypass, which might very well solve the problem, but why should I need a bypass when I have the Dimmer 2 wired with a neutral?
Thanks for any help with this issue..
The distance between the Fibaro dimmer 2 module and the light could also be a problem. Good explanation in this video:
