Setting and Getting Global Variables
I couldn't delete my question so I edited it and turned it into a description of what I did.
I want to set two global variables in two separate Lua scenes. (Both are manually triggered)
I then want to access those global variables in another scene. (Triggered based on time of day matching global variables)
I created a variable called Time and a LUA scene called TimeTrigger.
%% properties
%% autostart
%% events
%% globals
if (fibaro:countScenes()>1)
then
  fibaro:debug('Scene already running')
  fibaro:abort()
while (true) do
  local currentDate = os.date('*t')
  local currentTime = string.format('%02d', currentDate.hour) .. ':' .. string.format('%02d', currentDate.min)
  fibaro:debug('Time = ' .. currentTime)
  fibaro:setGlobal('Time', currentTime)
  fibaro:sleep(60*1000)
I then created a LUA scene called 6amWakeUp (and 5am, 7am, 8am, 9am)
%% properties
%% events
%% globals
fibaro:setGlobal('WakeUpHour', '06');
I then created a LUA scene called 30WakeUp (and 00, 15, 45)
%% properties
%% events
%% globals
fibaro:setGlobal('WakeUpMinute', '30');
I then created the scene to open roller shutters/blinds in the morning
%% properties
%% events
%% globals
Time
local time = fibaro:getGlobal('Time')
local WakeUpHour = fibaro:getGlobal('WakeUpHour')
local WakeUpMinute = fibaro:getGlobal('WakeUpMinute')
local WakeUpTime = WakeUpHour .. ':' .. WakeUpMinute
if
  (time == WakeUpTime)
    and
  (tonumber(fibaro:getGlobalValue("WakeUp")) == tonumber("1"))  --[[This is a 0/1 toggle variable so I can turn off the morning wake up--]]
then
  fibaro:call(53, "open");
  fibaro:call(56, "open");
  fibaro:sleep (10000)
  fibaro:call(222, "open");
  fibaro:call(74, "open");
...etc
Edited by Lenny212
Solved issue and changed text from question to solution
5 answers to this question
By the way you don't need the first scene.
Set the last scene in loop every minute and compare the time directly there.
Less load on HC2.
Right now you have two scenes running every minute..(first and last).
Another suggestion is to create Virtual device to set wake up time and not to execute so many scenes....
Edited by cag014
    Thx @cag014, I have created the first scene as I may use it as a trigger for multiple scenes down the track.
    Edited by Lenny212
    You can use same solution that you did using "while(true) do" loop.
    But there is Fibaro's function setTimeout(Func_Name, sleepTime)  for this purpose.
    Set scene to Automatic
    Please consider to create Virtual Device with buttons to set wakeup time.
    EDIT: function mane
    Right now I see only the last scene with global trigger. I don't think you need to trigger other scene using global variable "time".
    Keep using setTimeout() function.
    Edited by cag014
    Thanks @cag014, I have learnt a lot about Lua coding and coding structure from your example above.
    Please pay attention...  I did mistake on line setTimeout(WakeUpTime, 60*1000)
    should be setTimeout(isWakeUpTime,60*1000)
    wrong function name.. sorry
