ID0 error, read the manual
While I was adding devices yesterday to a new system, I got something like this:
ID 0 : error of the control unit, please check the manual
It apeared few times while addinig new device, in the adding window. As we all know, there is no manual where this info can be found :D so I would like to ask here, did anyone had the same issue?
The devices got added succesfully, no problem there. But the error apeared few times
8 answers to this question
Happend to me as well. I tried again and if error appeared i rebooted HC.
    Funny enough right? :D There is no such manual and Fibaro ask you to read it :D
    ID:0 has always something to do with error on Z-Wave chip. I believe there is some process stucked and it prevents HC doing something in inclusion mode.
    I also had following error few times: ID 0 : application rejected request. - appeard during battery device inclusion. And device needs to be waken up.
    On 09/11/2017 at 12:24 PM, I.Srodka said:
    Hi @HomeSystem.sk,
    Which device?
    Popp radiator valves, fibaro wall plug.
    Hi guys!
    I would be very glad if you could provide screenshots because I'm quite sure that this "read the manual" part doesn't exist ; )
    @I.Srodka, I do not have exact screenshot, but check Fibaro translation portal for HC2.
    On what firmware version did you happen to see this error?
