Setting Fibaro Wall Plug Gen5 Switch State
  • Hi ,
I've got a strange problem with a LUA Script on Domoticz 3.8153 .
The Script should set the plug state on
if the Plug "Leistung Steckdose Wohnzimmer Entertainment" has more power than 90 Watt
and the
room brightness of the brightness Sensor is lower than 200 Lux
and the
light on the ceiling is not switched to on.
The script is killing the plug if I set the state with the Content of the variable target_state_stehlampe ( which is On or Off )
but is currently working for few days with the below solution.
Any suggestions why the plug is not responding anymore if the content of the variable is written to the commandarray ?
Currently the plug goes "offline" after a few days , but I can't see the reason why it does behave so . The error lin in the log is like
OpenZWave: Node has failed (or is not alive), Switch command not sent! (NodeID: 52, 0x34) .
Is it possible that multiple On orf Off Commands are forcing the plug to go offline ?
Below the code of the lua script :
CODE:
