RGBW Controller
Hey,
I got an RGBW controller to control a new LED set up i'm doing on the outside of my house.
My hope is to include this in a zwave/smartthings network.
I have a 24v power supply for our LED since they are 24v LED's.
That supply has V+, V+, V+, V-, V-, V-, Ground, Neutral, Line
The RGBW controller has 12v in, ground, In 1-4, RGBW
My question is how does the 24v power supply wire to controller's in 1-in 4?
thanks!
11 answers to this question
4 minutes ago, Jp12787 said:
any idea about the V+ and V- on the power supply?
sorry. not clear to me. what is your question about +/-?
how to understand where "+" and where "-" ?
Ohh... actually I use a device like this
but...
I think your power supply can't take "selfy" :D
can you take a picture of your power supply here :)
thank you!
for 24v power supply LEDs you should use 24v power out a controller. I am not sure what PWM 12v enough for 24v  LEDs
btw,  please say a model for your device... I'm so sorry but I don't believe in your hopes :)
    are you saying you don't think this will work?
    this is the controller
    the 24v i just wire it into Line/Ground and then out to RGBW to the LED's? dont worry about In 1-4 since those are for sensors?
    nice choice!
    but it works with 12v LED strip.
    sop, according to FIBARo description:
    The FIBARO RGBW Controller is a universal, Z-Wave compatible module that controls LED, RGB, RGBW strips, halogen lights and fans via 12 or 24 VDC. The device allows you to change the color of the lights from your mobile device whenever you want. Additionally, the controller supports up to four 0-10V passive analog sensors such as temperature sensors, humidity sensors, wind sensors, air quality sensors and light sensors. All IN and OUT terminals may be user-configured for LED control or 0V-10V signal readouts.
    so, it's ok for 24v!
    Image result for FIBARo RGBW Controller how to
    so, RT*M
    Just now, 10der said:
    nice choice!
    so, RT*M
    got it so power in-- red green blue white out. and power from the 24v power supply to the LED
    but...
    thank you!
    Here you go
    Sir. you do not need to use this device with FIBARO RGBW controller.
    you need just simple find 220 (120 in the USA) to 24v power supply.
    about your device:
    Features and Specifications
    Input Power: 110/120VAC (can also be configured for 220/240V operation)
    Output Power: 24VDC 21A Max. (500W)
    Connection Type: Direct wire screw terminal block
    Power Input Terminals: 3 (Ground, N-Neutral, L-Load/Hot)
    Power Output Terminals: 6 (+,+,+,-,-,-) [single rail]
    Power conversion efficiency: 82%
    Power factor: 0.9
    Ambient operating temperature: -22°F - 140°F
    Active cooling
    Short circuit and over-current protection
    Non-dimmable
    so. as I can understand
    L & N  & ground => to 110V socket
    and you can use any pair V+ and V- outputs for 24v
    JFYI
    Have a nice day!
    about your device:
    Power factor: 0.9
    Active cooling
    Non-dimmable
    Thanks yea i have LED's that are about 150w per and i'm using 3 of them which is why the 500w power supply is needed.
    So are you saying i can use the V+ an V- into the Fibraro? where do they wire into which ports?
    Any idea how i then power the LED itself?
    here is
    24 v to FIBARO controller as power
    and V+ & V- to your LED strip power
    IMHO
    8 minutes ago, 10der said:
    here is
    IMHO
    got it so V+ and V- jumper together and go one line into the LED strip...
    yep! another "V"s (as I can see you have 3 out) can connect another 2 LED strips.
    so
    V(1):  FIBARO + LED1
    V(2):  LED2
    V(3):  LED3
    somehow or other
