[SOLVED]Multiple iOS devices (duplicates)
Hello team,
Can anybody explain why i have duplicate iOS-devices on my HC2?
I have one iPhone 7 Plus and one iPAD Pro.....
Why are these created ?
Maybe if you do an update from IOS 10->11 ??
Also, which ones would I delete ??
Thanks in advnace !
/Torbjorn
Hi @Torbjorn!
It is very likely that iOS upgrade changed this string as some security measures could have been changed by Apple.
You can test it out with some push notifications.
Setup a scene which will send the selected push notification to selected devices and then remove those that won't receive.
Alternatively, you can remove all devices and log in again on both devices. You just have to watch out if you have some scenes where they are used so you will have to rebuild some scenes/Lua codes.
     @I.Srodka
    Thanks for your fast reply !
