Guest jodohl
Could someone expand my horizon on the following?
I have simple HC2 Block Scene:
TRIGGER: The time of day is 10:00 am AND a global variable has the value "Away".
THEN: A second scene called "Leave" is run.
(I use this to turn off lights that are automatically switched on in the morning also when the whole family is absent for several days.)
Why does this scene apparently require 2 socalled "running instances"? I thought this was a piece of code simply running a loop checking the time of day and the variable value?
Edited by jodohl6 answers to this question
