[SOLVED]Fakepath while adding the icon
I have the same problem with fakepath...
After read this, I try by ip address but it not work because I can't enter in HC2... stay turning arround and don't enter.
I have a "i" in my toolbar (it seems it not secure...)
What should I do?
Hi @AlexVidigal,
The issue of fakepath was mentioned many times and IT IS NOT AN ISSUE. It is like that by design, it's a security measure.
Yes, icons can be only added in local access (via the IP address).
You can try to follow those articles in our Knowledge Base:
