[SOLVED]Lights on/off time stamp
Hello, i want to make program to turn on/off lights between time which i setup. For exapmle, between 12-16 turn on between 16-12 turn off. Could u help me. HC2
Edited by Adios
11 answers to this question
In block or LUA?
    In block and in lua i wanna learn it
    And finally
    Ok. Now i ve got motion sensor. I wanna light on when move is detected but only between 16-20. When move is detected before 16 or after 20 lights have to be off. I cant do it with yours examples.
    Here is a simple scene for that:
    Please change motionID and lightID (marked red) to your real device IDs
    %% properties
    motionID value
    %% globals
    local devID = tonumber(fibaro:getSourceTrigger()["deviceID"])
    local cTime = os.date("*t")
    if (cTime.hour > 15 and cTime.hour < 21) then
         if ( tonumber(fibaro:getValue(devID,  "value")) > 0 ) then
              fibaro:call(lightID,  "turnOn")
    else
       fibaro:call(lightID,  "turnOff")
    Works as requested between 16-20  not tested.
    BTW what about when the motion sensor goes back to safe, do you need to turn off the light?
    Edited by cag014
    Thanks today i wlll check. Yes when motion sensor goes to 0 berweetn 16-21 lights off
    I did something like this
    if (((cTime.hour >= 15) and (cTime.hour < 23)) or (cTime.hour == 23) or ((cTime.hour >= 0) and (cTime.hour < 8))) and (tonumber(fibaro:getValue(5, "value")) > 0 ) then
      fibaro:call(9,  "turnOn")
      print ("wlaczono")
      else
      fibaro:call(9,  "turnOff")
       print ("wylaczono")
    Edited by Adios
    looks OK, but as we all know the best SW engineer, is the lazy engineer who writes as minimum code as possible to provide better understanding of the code from the first glance
    So may I suggest follow line (does the same):
     if ( (cTime.hour > 14  or  cTime.hour < 8 ) and
    but either way it should work.
    Edited by cag014
    Thank you. One more question... How can i make somethimg like that... Move sensor is ON, light is ON, when move sensore is OFF then wait 10 sec and light OFF. For my example which is above.
    Sorry about late reply, but here is the example for 10 seconds delay.
    It might be that the scene will have few instances (especially if you'll increase the 10 seconds delay to bigger value), but it should work correctly.
    In general the idea is to wait 10 seconds then  if the sensor still off (safe) and last change of the sensor happened more then 10 seconds ago to turn off the light.
      print ("wlaczono")
      else
      fibaro:sleep(10000) -- sleep for 10 sec.
      if (tonumber(fibaro:getValue(5, "value")) == 0 and os.time() - fibaro:getModificationTime(5, "value") >10 ) then
           print ("wylaczono")
