Fibaro Roller Shutter FGR-222 Reporting Wrong Position
I installed couple of Fibaro roller shutter FGR-222, however, two of them are not reporting correct position. No matter how many time I do callibration, it is always showing closed in HC2 interface.
The HC2 controls them just fine when openning or closing, but even though it still always shows closed in the interface.
I followed some trouble shooting steps in Fibaro manuals but with ni success, has any body ran into such issue previously?
5 answers to this question
Hello @Malath!
You said that you have a couple of FIBARO Roller Shutters. Could you swap the pair of them? The one module that works fine, put in this other place, and the module from this place which makes us trouble put to the previous place of the first module.
    Hi.
    I tried replacing the module with a new one. Same behavior
    It could be some thing related to configuration which I am not aware about. I have 3 of them working fine.
    I wasn't talking about a new one.
    So if you put those that work fine in other places, they don't work in this place right?
    Okay, did you try to exclude and include it again?
    Did you do the SOFT reconfiguration?
    Did you reset the module?
    What motors do you have?
    I have this issue since ever. No matter I have a scene closing all blinds and than lamels, there are from time to time still some reporting that they are partially open. Same in the morning, when I open all lamels by scene to  100%, some of the shutters report closed position until I change it on this specific device only.
    I tried the soft reconfiguration and tried resetting. I haven't tried to replace the proper ones with these two.
    These two are working fine, except that icon always shows closed.
    I am using Somfy motors with below wall switch same as attached photo and setting are set to Toggle switch in the HC2
    Also if you can see from other attached image, all roller shutters are open but two are displayed as closed.
